Made two more flap torque tube bearings. Having a problem getting close tolerances on tube and bearing. Bought a new 1 inch hole saw but only got it .005 better. That is setting it up on the drill press. It seems the flaps may not be that tight anyway with the actuating arm set up in a slot. I will have to watch that. Started to unstall new bracket and gusset, need to back drill first the bracket then the gusset.
