Worked rt fwd longeron stiffener. Had to pull in longeron quite a bit to make it fit.. Will try to order the modified engine mount brackets with the canopy hinge fitting on it. They are longer and the engine mount bolts are not welded in. If I make the top cowl removable (with anchor nuts) the engine mount bolts are right there.
