Worked rudder set up at rear fuselage. Had previously drilled the longerons at the rear but drilled holes at 10 and 20mm but the lower hinge requires only 10mm. So will have to get a piece of .063 t 6061T6 and make the lower hinge a little longer to pick up the other hole with good edge distance. Joggled the Z strips and fitted the LH forward longeron.
