Riveted angles on top wing skin for tip and started fitting fiber glass tip and cutting the end cap. Next will remove nose skin and finish tank wiring and plumbing and ground. Have to open up drain and vent holes, rubbing a bit. Still have pitot tube to rivet on and connect, have tubes hanging outside bottom skin and don't want to lose them inside.
