Tried fitting horizontal stabilizer onto fuselage. Everything lines up level except the attach brackets are to tight and would put a strain on the fuselage fittings. Made two shims and drille out fwd brackets, will try fitting tomorrow. I may have to do rear fittings and use a heavy shim. Have .025 fitted now, still have to finish them if the shim fit is O.K. Ordered battery (Odyssey 680) Will place it behind rt seat and I would like to finish thte wiring up before I install the canopy.
