Laid out elevator, checked clearances with stabilizer and rivet lines. All O.K. Mis-drilled lower elevator horn and ordered new one.. Necessary to order 90 degree drill for inside the fittings. Laaid out hinge. Rough cut the rudder movement cut out. Quite a bit more work than I thought originally.
