Finished wiring up #2 ignition. Number two fuel and ignition wired directly to battery and controlled by the number two switches. Will enable battery bus to be shut off and run engine on number two. There will be no instrumentation but engine will run. Will note to use number one for take offs and landings using the safety switch to cut off fuel if oil pressure drops.
