Cut fabric for seat backs. Started gluing the rt side. Will glue the long runs and sew the corners to keep them tight. Had to order more MAS epoxy for the seat bottoms. Ordered from Zenith the steering rod covers. I was skeptical about the threaded rod sliding through the slide. I am sure there will be vibration in that set up, it has to be be loose enough for everything to slide in and out and up and down. i would still like to do something with the canopy latch. Need a latch that will pull the canopy down and tight onto the rails and locks with a noticable feel.
