ALBERT'S WEB SITE
Date:  3-10-2008
Manual Reference:  None
Brief Description:  Vacuum system
Installed filter for Venturi vacuum. Had to use a double inlet filter, seems as though that there isn't much around for a single instrument. Most meant for pumps. Won't really be able to check it out except fpr flight. Held good using the vacumm gauge but that didn't include the filter and venturi ends.
Inlet filter mounted on shelf
Vacuum gauge, trim indicators, ELT panel
