Got the canopy sitting on the bows all the way around. I have a gap at fwd left and right corners yet. I will have to decide on that. The fire wall is about as far as I can go till I get an engine. The right side is fuel, the left is oil. On the right you have gasolator, two fuel pumps, and teed off is the primer solenoid and the fuel pressure transmitter. On the left side you got oil filter, oil temp xtr, and oil pressure xtr. The oil separator will be mounted on the firewall shelf. The engine ground block is bolted through the firewall to the aircraft ground block on the cabin side of the firewall.
