ALBERT'S WEB SITE
Zodiac XL
Corvair
Engine tear down
Crankshaft is the correct one.
The crankshaft would not turn over so very tough getting it apart. Had to split the block to get at rod bolts.
Three studs will have to be changed
Upper lft stud of rt cylinder sheared
Valves removed, guides very close, will probably replace
Zodiac XL Home
1187
Cabin
Cowling
Dual stick
124
317
Instruments
Landing gear
25
Lft Wing
Mods
Rt wing
Updates by Zenth
Wiring
