ALBERT'S WEB SITE
Zodiac XL
Corvair
Engine teardown
Finally got block split. Crank is the right crank. Crank looks O.K. Some corrosion but will probably clean up, the most is a .010 turn. Will have to be magnafluxed, nitrided, nose end threaded for safet pin then set up.
Before separating the block
Some cylinders had to be cut away
Finally block is open.
Zodiac XL Home
1187
Cabin
Cowling
Dual stick
124
317
Instruments
Landing gear
25
Lft Wing
Mods
Rt wing
Updates by Zenth
Wiring
