Installed vacuum gauge and artificial horizon on panel. Still have plumbing to do. I wanted the gyro in the middle but it is a little wider than the standard instruments. It's a RC22-7. The vacuum gauge is upper leftby trim indicators. The LRI will be right above the ASI. Below the Airmap 1000 is an ICOM A200 transceiver. A handheld ICOM NavCom mounted on the baggage shelf will back everything up. The boots on the floor from a Yamaha snowmobile will be for the nose steering rods. They have a metal flange that will be bolted to the wall and a clamp on the rod.
