Finished priming and riveting rudder brackets. Checked rudder travel, comes in at 22 degrees on each side. Put a protractor on the rudder spar and using the laser to center and check the throws. Limits are 20 - 22 degrees on bothe sides - 44 degrees total. Will put the stops on at 20 degrees to give a little cushion on the frame.
