Cut down handle to fit barrel. Had to shorten and cut down on diameter. Drilled a hole and tapped for a 10/32 screw and put it in the drill press and used a file. Installed the 1/16th teflon rub strips on the cowl at the fwd pivot point of the canopy rail to prevent rubbing.
