Drilled the holes for the latch mechanism too low and the cable tabs don't turn enough to be sure if the cable stretches it will work. Will put doublers on the inside and outside trim and grind the tabs down a bit to relieve the problem. I just followed the plans and didn't think it through so I have more work to do. It will make the latch a little more solid also. Made doublers.
