Installed canopy again and checked fit on bows. Front fits real well on bow and cowl, rea bow is about 3/4 inch lower than glass. Marked canopy for cutting and removed. Bent Rt inside trim piece. Making fwd cowl out of three oieces so remval is easy for working. The center piece is riveted on and the other two will be J-nuts. This gives good access to the back of the instrument panel without removing to much.
