Worked the lower enginr mount brackets. Just have to finish drilling and installing another bolt on each side. Used a piece of the fuel tubing to act as a drill guide for the bolts. Had to cut down the O.D. just a bit. Then inserted drill tubing into mount and firewll and used that as a guide. Line up was good so it worked well.
