Drilled fitting for nose gear lower bearing. Takes AN4 bolts with threads tapped in blocks. Don't have AN4-6 bolts. Don't know whether I ever got them or what, will order some. Made up the two lines from parking brake valve to cabin floor blkhd fittings.
Metal lines from valve through floor aft to the landing geat strut
