Put anchor nuts on the arm rest so as to be able to take top off all the way. Will put center console on a hinge attached to instrument panel if the fuel selector works out O.K. I will have rigid lines in the cabin. If not I will use anchor nuts there also. Worked some more on flap actuator mounting, mainly to check my parts.
