Made two rear 6B14-1s. The ones with the kit did not pick up three holes verticall on the rear, front was all right. The hole pattern is different front and rear gear uprights. Driolled and riveted top longeron splices on top side including 6B12-2. Laid out flap parts and can't find one of the 6B19-5s Flap Control Bearing. I didn't check off on inventory sheet that I had them, but the one I have the part number tape was ripped in half as though I had separated the two? If I don't find it thia week will order a new one.
