Removed right fwd panel. Filed down Gear channel to clear weld. Installed the dual stick roughly rigging it even, will have to check travel later. Does fit under the instrument panel, not by much but does. All tight except lock nuts on rod ends. Deburred and riveted rt side of seat back blkhd
