Re-aligned saw horses to try to get a more stable fuselage. New alignment more stable and requires less shimming. Squaredf gear channel, level larerally and longitudinally with no shims. Aft section is squared same way with no shims. Front section looks good but will have to check. Fitted the last fout vertical L channels on aft section with gussets, all opened up to A-4 butnot deburred. Hung on fwd top longerons to see how line up is with both top longerons level. Will have to figure out top engine mount bolts, would like to have the mount from WW but haven't heard anything. Just that he is working on it.
