Drilled side of side skins for rudder cables and fitted and drilled housing. Deburred and zinc chromated the rear vertical L braces. Laid out nose gear housing and checked for parts for the spar jigs. Ordered four saw horses from Harbor Freight will have to movre fuselage from work bench. Will try putting it in basement long ways. Need to make sure center line is from nose to tail. Can't do much more without placing the fwd and aft pieces together. Drilled aft bearing for control torque tube.
