ALBERT'S WEB SITE
Date:  2-9-2006
Manual Reference:  6B3
Brief Description:  Lwr rudder hinge
Finished up the lower rudder hinge poit.
Pilot drilled and opened up bolt holes and tie down fitting.
The bottom fitting is longer to accomadate mis drilled holes on longeron
but it will be stronger because of that.
Also using four bolts on top fitting as per revised drawing.
Using four bolts insyead of two
Lower fitting longer
