Installed top wing skin and upper nose skin.. Drilled nose skin, nose ribs. Laid out and drilled main spar from fuel tank outboard. Was waiting for nose rib #8 Made stand offs for pitot statc lines, using adel clamps. Drilled out fuel tank cap hole, still needs more work, will install doubler around filler cap. Laid out landing lights on nose skin and worked the bkts.
