Drilled end of tank and installed fuel Qty transmitter. Calibration off or fuel float arm is not right, bent to specs but using an ohm meter the qty is off top and bottom of scale. Hopefully it won't be too much at low end. All scews tight. Fuselage kit arrived in Plattsburgh Yellow Freight. Bob Peacock will pick it up again.
