Finished the upper and lower horns, drilled the support bkt inside. All ready to complete. Opened lower skin for access hole for trim servo, fitted inspection plate. Positioned servo and drilled and clecoed to skin and cut down servo rod. Servo ready to be tested and rod adjusted if necessary.
