I have painted parts all over the place with more to go. The skins need time to cure so they are spread out all over. Several newly made rib attach angles and bell crank attach parts were primed. What will be next is the remaining ribs, the flaps and ailerons plus attach parts, such as two Duckworks landing light installation kits. As this was day one of my new learning experience, I did not bother with a couple runs or less than perfect spray patterns. The primer is very satisfactory. The pressure regulator needs improvement. I have a master valve nearer to the air compressor and air dryer that I will dial down first to see how that works. Otherwise, I will put a better pressure regulator at the gun location.
Had a little leftover paint in gun so one more rib finished.
