Wendells RV-6A
Date:  12-31-2008
Manual Reference:  Found my engine
Brief Description:  Lycoming IO-360 B1E
A great find with this Lycoming IO-360-B1E. We found a Piper Arrow that was parted out and this engine had 800 SMOH with a new ECI crankshaft and all accessories overhauled as well. It arrived with all accessories, including prop governor, mags, vacuum pump (getting rid of that), fuel pump, starter, alternator. We knew this engine had a rear facing fuel injector servo so the seller made good on an offer to replace the sump with a new Superior forward facing cold air induction sump for a modest price and the deal was done. This was the first chance for my daughter to help out and I put her to work after the delivery truck left. In no time we had the old baffling removed and the engine cleaned up. I spent a couple hours scanning two engine logs into my computer page by page for permanent records on this certified engine. It is now ready for a constant speed prop when I get around to making that deal happen.
Original baffling had to be removed.
Engine looked good later.
Putting daugher Julia to work!!
