Brief Description: Update to latest Pressure Senders
I took the opportunity of replacing the old VDO pressure senders with the newest V2 Kavlico Oil and Fuel Pressure senders. Both are rated up to 150PSI and recommended for fuel injected engine by Dynon. This required splicing into the manifold pressure 5V power and common ground wires Changed the EMS configuration to the required Kavlico V2 150PSI option. A quick test of both resulted in solid pressure numbers. Good bye VDO.
14 year old VDO senders.
2 day old Kavlico V2 senders.
Matched the new senders to the correct configuration in the EMS.
