Wendells RV-6A
Date:  8-27-2020
Number of Hours:  6.00
Manual Reference:  Vertical Stab
Brief Description:  Final Drill Vertical Stab attach holes.
I drilled enough #30 holes in the forward spars to allow me to remove the work and finish drilling the remaining F681 holes with better access. I will rivet and bolt the spar, spacer, F681 and steel reinforcement onto the vertical stabilizer. Re-installing it, I can final drill the 4 holes in the horizontal stabilizer spar so it can also be bolted up. I also have some finish drilling on the rear spar and fuselage attach points to be 100% complete, including the rear steel tie down plate.. I can invision the end, and it makes me smile.
Top 2 will be #12 drilled for AN3. Bottom 2 will be AN4 plus one more.
Drilled enough #30 to ensure solid placement.
Ready to come off for finishing.
