Wendells RV-6A
Date:  7-28-2020
Number of Hours:  7.00
Manual Reference:  Right Wing
Brief Description:  Torque Main Spar Nuts
Now I can begin inserting final bolts and also start torquing the nuts. Before beginning that, I had one AN3-16A bolt that was prevented from coming through the steel gear weldment hole from the aft side on the lower outermost spar hole on the right side. I felt it hesitate ever so slightly as I tapped it into place. Sure enough, the thread got slightly damaged coming through the steel gear weldment and I could not start a nut onto it. Had to remove two close-by side weldment bolts so I could get a drift pin straight onto the bolt and tap it backwards out of the hole. After that I had to rig up a special reamer to ensure the hole was uniform size throughout all the pieces.
Bottom left AN3 bolt. After old one was removed. This new one was able to be inserted from the front.
Looking down at the 4 bolts into the fuselage side. Left 2 bolts were removed for ease.
Throwaway AN3-16A shows damaged threads. My bad.
