Wendells RV-6A
Date: 6-22-2020
Number of Hours: 4.00
Manual Reference: Wing Attach
Brief Description: Reinsert the wing for last time
Its finally the day you realize the wing is going back in for the last time. I partially inserted it, supported it outboard of the pitot area, slid a temp pin in place to keep it where I wanted it, and began doing the final work. That work consists of running the AOA and Pitot lines into the fuselage, fishing heated pitot wires to the pitot area, fishing power wires all the way to the wingtip. This wing has a 5 wire aileron trim connection, taxi light power, APRS power, nav and strobe power plus shielded ground, Archer antenna RG400 cable. The Byonics RTG APRS unit has its own GPS antenna, and transmitting antenna out there in the wing tip too. All I need is my Ham Radio License to make that legal. Its on my short list.
Full length Pitot and AOA lines enter fuselage and end at Dynon ADAHRS
Heated pitot power wires and lines await final installation.
Most of the wires fished through. Two more to complete.
