Wendells RV-6A
Date:  4-20-2018
Number of Hours:  3.00
Manual Reference:  Wing Sweep
Brief Description:  Trim Right Wing Rear Spar Connection
One more and hopefully last effort to trim the right wing fuselage bar extension that interferes with one wing spar rivet, preventing wing from sweeping aft the last quarter inch to align the four plumbobs off the front of the two wings. It worked and now the right wing can be plumbed exactly. The 5/8 clearance in all directions is visible by seeing the rear spar marked line to the inside of the fuselage bar line. That means we have clearance for safely drilling the hole. There's not much room for error so I'll be careful squaring up the drill when it comes time to make the hole.
Outer plumb bob on right wing is exactly lined up now.
Safety margin is inside the 2 horizontal lines, just left of vertical line.
View from front. Hole will start just right of vertical line inside of 2 horizontal lines.
