Wendells RV-6A
Date:  4-10-2018
Number of Hours:  4.00
Manual Reference:  Wing Bracket
Brief Description:  Fuel Tank Attach Brackets to Fuselage
Until wing sweep and incidence are final set, I can't make the final bend on these 3/16 attach angles. Each one is a custom fit with a slight bend because the fuselage and tank are not 90 degrees at the connect point. I did the preliminary bending and trimming of the edges per plans. Ready to fit, drill, prime, paint and install with addition of an inner support angle, small spacer, 1/4" nut plate, and slotting at fuel tank mating bracket.
