Wendells RV-6A
Date:  3-8-2018
Number of Hours:  3.00
Manual Reference:  Test Mounting
Brief Description:  Test Fit Wing Install
One person (me) was able to remove wing from portable wing stand and insert into fuselage with use of extra wing tables I made long time ago. Was doable, but will use helpers when it comes to bolting in place for wing sweep and incidence. Goal today was to see if I could do it, and to notice where I will have to trim spar web to allow wiring loom to nest safely. I'll make the cut, put protection in place and we'll be ready to bolt 4 holes to hold wing snug.
Test fit.
Test fit.
4 inches shy so wire loom is not impacted. Outlined where to trim spar web.
