Wendells RV-6A
Date:  8-11-2014
Number of Hours:  3.00
Manual Reference:  ADAHRS
Brief Description:  ADAHRS wiring 2
After I ran the Dynon network cable forward and cut it to length, I had enough leftover to make a correct length Network cable connecting the ADAHRS units to the Dynon Hub (mounted below them). A shorter 3 ft network cable I was using needed to be 5.5 feet to route it over down and back to the Dynon network hub. I had fun cutting, stripping, crimping, and heat shrinking network wires today. Sweat drops clouding my vision while I tried to feed the DSub pins onto the stripped wires were my only real problem. The finished cable was secured and plugged in. Testing proved I did it correctly.
ADAHRS network cable runs over to fuselage bulkhead then down to Dynon Hub.
Secured the connection with zip ties.
The big picture.  All thats left are pitot and AOA lines.
