Wendells RV-6A
Date:  8-11-2014
Number of Hours:  3.00
Manual Reference:  ELT
Brief Description:  Mounted AK-450 ELT-4
Radio Shack had telephone wire butt crimp connectors for the 26AWG wire splices back at the ELT. I staggered them so I didn't have a big bulge where 4 splices went. Crimped them all, and heat shrank the splice area for stability. An Adel clamp on the ELT mounting assembly secured the wires and I plugged them in. I haven't permanently mounted the ELT antenna yet, so I rigged one and tested the unit as well as tested the panel mounted remote activation/reset switch. During the first 5 minutes after each hour, you can test your ELTs without false alerting. I did that. It signaled to my handheld loud and clear. I also used the panel switch to activate it and reset it. It all worked. Yea!!!
26AWG wire is not easy to work with. Molex crimper squeezed the wires nicely.
Heat shrink covered the staggered connectors. Adel clamp holds wire smartly.
Yep. ELT singing like a canary and shuts off using this panel switch/indicator.
