Wendells RV-6A
Date:  3-12-2014
Manual Reference:  Oil Cooler
Brief Description:  Install Oil Cooler and Brace
I am thinking about putting 063 angle aft of oil cooler forward flange to distribute the clamping load across the whole flange instead of pressure at the bolt holes in front of the aluminum spacer tubes. I would trim the spacer tubes by .063 to allow same tight fit. We'll see.
Oil lines (-8 fittings) were so large compared to brakes and fuel lines. I had to use 7/8 crows foot wrench with my 3/8 drive socket to maneuver in some tight spaces to secure the B nuts properly. It worked.
Maybe 063 angle stiffener to sandwich the oil cooler flange btw baffle and tube spacers.
Rear inboard baffle flange cutout to clear engine mount.
Added 3rd bolt to secure oil cooler brace on engine side of baffles.
