Wendells RV-6A
Date:  11-4-2013
Manual Reference:  Alternate Air Door
Brief Description:  Install Horizontal Air Intake Plenum 3
Chose the location for mounting the Horizontal Intake Alternate Air Supply Door Kit. Marked the location for a 2 5/8 hole and drilled starter holes around the circumference. A hand held hack saw blade easily connected the adjacent drill holes and I had my cutout. Plan recommended a 10 degree clockwise turn from level for the mounting. After playing awhile with the ultimate throw, I chose a slight counter clockwise tilt to match drill the intake bracket to the fiberglass plenum. The side of my plenum was surprizingly vertical and will only require a little flox/epoxy under the bottom edge to seal it. The example in the plans required a significant epoxy/flox buildup to get a vertical mounting surface. I guess they improved quality control on the plenums.
This rotation slightly forward works very well with pull cable.
Cable routed past engine and up through firewall passthrough.
Full open. The throw used every notch at the handle, but it gets reset on the ground...
