Wendells RV-6A
Date: 10-19-2013
Number of Hours: 8.00
Manual Reference: Baffles
Brief Description: Install Engine Baffles 8
Paperclipped the forward baffles that go behind the starter ring, and marked, trimmed, and reinstalled with a 3/8 gap on top. Nearing the end of the baffle work. I will need to finish the horizontal intake/baffle ramp connection and then remove, prepare, prime, and paint the whole thing, rivet it together and install again, hopefully for the last time; I can't believe a month has passed working on this cowl, baffles, plenum, etc.
All top baffle surfaces trimmed to proper clearances. Yea!!!
Tested the oil cooler and it still fits with clearance. Need to make a brace fr #4 cyl to rear baffle
Forgot to open up the angle to fit the tinnerman washers/nut, etc. that plug this hole.
Copyright © 2001-2020 Matronics. All Rights Reserved. |
