Wendells RV-6A
Date:  5-17-2013
Manual Reference:  Tunnel work
Brief Description:  Fit 7A Tunnel in the 6A - 4
Mounted the Andair fuel selector on the top plate, after I had staked 8 screw heads (4 on each fuel inlet fitting). To stake the heads, I used the spring loaded center punch and aimed the point at the circular recess made by Andair for this purpose. Snapped the center punch and the screw head smushed slightly into that recess. Thats what Andair told me to do when I visited their booth at SunNFun. Made the compound curve fuel line connection between the fuel selector and the fuel filter. 2nd one worked real good. 1st one would have worked too if I had remembered to add the Bnut insert before flaring the tube.....
Lastly, I rough assembled the pieces to get the big picture on how it will all come together in the airplane.
Short fuel line between selector and fuel filter. Complex curves.
Don't know if I'll use the 90 deg adapters for fuel lines yet.
The BIG picture....
The BIG picture....
