Wendells RV-6A
Date:  4-24-2013
Number of Hours:  4.00
Manual Reference:  Sniffle Valve
Brief Description:  Sniffle Valve Installation
Bent some 3/8 fuel line to make the drain line for the sniffle valve. It exits inbetween the two exhaust pipes and is coupled to the sniffle valve by use of rubber 3/8 fuel line and clamps. Also clamped it to engine mount very close to exit area for stability.
Easy routing with this Superior cold air induction sump.
3/8 rubber fuel line couples aluminum drain line to sniffle valve.
Exit area secured with adel clamps to engine mount.
