Wendells RV-6A
Date:  4-23-2013
Number of Hours:  0.00
Manual Reference:  Exhaust
Brief Description:  Vetterman Xover Exhaust Installation 2
All the stainless connector tubes and rubber hoses were installed. I have previously read there is interference with the nose gear and with other stuff, but I have to say unless I've got it in the wrong spot, this was a piece of cake. Had to trim the ends off two tubes that run under the nose gear leg and it was a little tight in places to lock down the nuts, but no problems at all.
I've expected problems and did not have any. Something's not right......:)
Support tubes and hose connectors in place both sides.
Shows I used the corner location on the Superior sump.
There's no contact here and actually has 1/2 inch free space between gear leg and hose.
