Wendells RV-6A
Date:  2-18-2013
Number of Hours:  5.00
Manual Reference:  ANL Fuse Blocks
Brief Description:  Installed ANL Fuse Holders on Firewall
Used 1/8 copper bus bar to make connections between the starter relay connection and the two ANL fuse holders. One ANL will protect in case of major grounding of the alternator back through the B lead. The 2nd fuse holder will protect against any shorting of the primary feed from the relay through the firewall to the VPX power bus. There won't be any shunt installed because the VPX does more than the Dynon shunt setup without using the shunt. One less thing to worry about. I have to research whether or not the ANL fuse blocks require a doubler or just some large area washers on the inside of the firewall.
