Wendells RV-6A
Date:  2-14-2013
Number of Hours:  4.00
Manual Reference:  More fittings.
Brief Description:  Electrical passthrough
Purchased two Safe-Air bulkhead fittings, one for each side of the firewall. Pilot side installed first. 1 1/8 hole cut, cleaned up, and then mounted the first fitting. Ready to add wires, then finish sealing it up. The EMS module wiring will use this exit. Struggling on best location for the other side. I will probably go with the same relative location on co-pilot side and get it done.
Really simple with good instructions from Safe-Air
Wires get wrapped with silicone tape and more firesleeve inside this hole.
One down, one to go.
