Wendells RV-6A
Date:  1-31-2013
Number of Hours:  1.00
Manual Reference:  Anti Rotation
Brief Description:  Switch Anti-rotation mounting bar.
Used scrap 063 to make a 1 inch wide strip that mimicks the switch mounting holes spaced on 1 inch centers. Under the mounting holes, I drilled .109 holes to catch the anti rotation lockwasher tab and therefore keep the switches straight up and down. You have the lockwasher on the switches, push the switches through the bar, then through the panel openings. The anti rotation lock washer tab engages the small holes from behind and as you tighten up the switch, it all just pulls together and all switches are held with one bar. I can make a smaller one for some of the upper left switches on the panel, as well.
