Wendells RV-6A
Date:  6-20-2010
Number of Hours:  0.00
Manual Reference:  Fuel Tank Baffle
Brief Description:  Fuel Tank Rear Baffle more
Turned the fuel tank over and took pictures of the business end for the records. Also noticed one pop rivet I forgot to proseal over so I mixed up tiny bit and did the job. I also can see where I will have to clean off a few minor spots where the proseal will interfere with the main spar when I mount the tank. Those 36 wood blocks worked very well to keep the baffle and tank skin tight together. I am also very happy with the Tank Dimple Die set. The slightly deeper dimple worked perfectly with the small amount of proseal under the rivet heads.
The big picture
The big picture
Capped all 184 rivets
Tank Dimple Die Set worked great
