Brief Description: Riveting the horizontal stabilizer 2
Continued with the HS-609PP bars. Riveted theHS-412PP and HS-413PP hinge brackets to the spar Bolted on the HS-411PP bearing to the spar Riveted HS-810-1 and HS-814-1 and HS-00003 to the HS-702 front spars Riveted HS-00006 and HS-00005 tot the front spar assembly
